HELP! Temp Gauge Prob Housing
BigRedM
10-08-2004 17:45:09
I was changing out my temp gauge and reamed the prob housing off flush with the head...How can I fix my screw up....Please Help!
Redmud
10-10-2004 08:12:07
 Re: HELP! Temp Gauge Prob Housing in reply to BigRedM, 10-08-2004 17:45:09
Big Red,
Are you talking about brass or steel, if it's a brass bushing, I use a short piece of hacksaw plade 5-6 inches long, grind down the back of the blade where it will go inside the bushing, make two cuts thru the bushing, sometimes I make four. you can tell when you get to the cast iron. then a small center punch will turn it out. if you make four cuts then you can cave the bushing in. I had to do this to my old jeep friday. if the bushing is steel then I use an EZ out, the EZ out needs to be the square type. and you can use the hacksaw blade on steel also, it just takes longer.
Redmud:
BigRedM
10-10-2004 16:51:04
 Re: HELP! Temp Gauge Prob Housing in reply to Redmud, 10-10-2004 08:12:07
Thanks for the advice...I was able to get it with a little heat and an EZ out. It was not hard once I got past the "OH CRAP" mind numbing feeling you get when something like that happens...Thanks again.
BigRedM
10-09-2004 16:55:28
Well....I guess I'll just have to figure this one out myself....
