444 tranny problem
Browny
10-12-2004 19:17:11
A friend of mine has a 444 that won"t come out of gear unless he shuts it off. Also the clutch and brakes stopped working. Does this tractor have a hyd clutch and what could be the problem with this tractor. Any info would be a help.
Ben in KY
10-13-2004 07:23:00
 Re: 444 tranny problem in reply to Browny, 10-12-2004 19:17:11
The clutch and brakes are totally seperate issues. It sound like the clutch needs adjustment or repair.
The clutch is mechanical, and so are the brakes. There is an inspection plate on the bottom of the clutch housing, 4 bolts and you can see what is going on with the clutch. Do a search in this forum on 444 and you should find several posts on the brakes, which are not fantastic even when they work properly. I know I have one :)
Ben
