1917 International Harvester Mogul 1020
Andrew Brown
10-13-2004 03:46:39
Does anyine know what lubricant should be used on the above tractor? It has a single cylinder petrol / paraffin engine lubricated by a total loss oiling system supplied by a force feed lubricator. MAny thanks for any info.
Andy
dej(JED)
10-13-2004 06:16:32
 Re: 1917 International Harvester Mogul 1020 in reply to Andrew Brown, 10-13-2004 03:46:39
Most guys I know use the equivalent of a 40w non detergent oil for similar applications. The contention is that an additised oil will not flow properly because of the possibility of additive seperation and clogging potential in a gravity flow situation. Bear in mind that the oils in that era offered no additives whatsoever.
Also the refining cuts used to obtain lubes then were very primitive, often allowing light ends to carry over into the lube.
