Wrong parts ?
Brent Fuller
10-19-2004 18:38:31
I recently bought some parts for my 40'A at a local tractor dealer. Problem is I think the woman had no clue as to what she was doing.I bought a radiator cap(part# 67448DD) and a tune up kit(part# IHTK1-H).The tractor has a magneto,could someone tell me if this stuff is right before I open it?
RAS
10-20-2004 09:10:46
 Re: Wrong parts ? in reply to Brent Fuller, 10-19-2004 18:38:31
Support Pro shows 67448DD as a pressure cab and 43983D as a non pressure cap. Both numbers are for an A serial number brake.
Randy in NE
10-20-2004 07:15:54
The radiator cap is part # 43983D. This doesn't mean that IH hasn't crossed it to something else that will work. My parts CD does not show a kit for the ignition. There is definitely a big difference between a Mag and a distributor.
caseman-d
10-19-2004 20:51:36
Did you inform the gal weather you had a mag or dist.? Working in parts myself it surprises me how many people don't even know what they have. I hear all the time "it don't make any difference because their all the same" so when you give them what they want " well that ain't what I want" so then I guess there not all the same then. So don't knock the parts person even if it may be a woman until you been in their shoes.
caseman-d
JR#1
10-19-2004 20:56:56
 Re: Wrong parts ? in reply to caseman-d, 10-19-2004 20:51:36
DONT FEEL ALONE, CALLED THE IH DEALERSHIP OVER HERE A WHILE BACK FOR A SEAL FOR MY CUB. THE GUY ASKED ME IF THE TRACTOR WAS OVER 50 HORSEPOWER!?!?!?
farmallman
10-20-2004 07:08:39
 Re: Wrong parts ? in reply to JR#1, 10-19-2004 20:56:56
Makes you feel good tho, eh?
Pa. Don
10-21-2004 15:12:18
 Re: Wrong parts ? in reply to farmallman, 10-20-2004 07:08:39
I'm not knocking all sales people, but I went to a parts store to get a regulator for my 'C'. She came out with a little piece plastic and handed it to me. When I told her that was not what I need she informed me that that was what the book called for. Sorry, try again. Second attempt brought a regulator for whatever type of car I have no idea. There were no terminal markings on it at all. Strike two. Luckily, the phone rang so I turned the book around and looked it up myself. When she finished on the phone I had the number for her to look up in the stock room. Viola, back in business.
Jim Becker
10-19-2004 19:30:23
That part number is a pressure cap. Won't fit an A.
MagMan
10-19-2004 19:02:38
I cant tell you the part #s but there is a lot of differences in the looks between the mag kit and dist kit. The mag has a Rotor thats about 2 to 2 1/2" across and the dist kit has a rotor a little bigger than a quarter.and the condenser will have a wire on it for dist and just a bolt type peg for magneto. HOPE THIS HELPS JON
Stan(PA)
10-19-2004 20:01:06
 Re: Wrong parts ? in reply to MagMan, 10-19-2004 19:02:38
I think you got the rotor sizes backward.....
Magman
10-20-2004 02:50:25
 Re: Wrong parts ? in reply to Stan(PA), 10-19-2004 20:01:06
No That is right for a H4 magneto rotor a J4 is small like the distributor if thats what you may be refering to. JON
