Farmall H
Andrew Betnzer
10-20-2004 15:41:58
I have an H without the serial number on the clutch housing, but it has a engraved number on the block near where the distributor is, the numbers are FBHM 375132 Can you use this number to identify it?
Andrew Betzner
10-21-2004 10:16:12
 Re: Farmall H in reply to Andrew Betnzer, 10-20-2004 15:41:58
Yep, all end with a W, thanks guys!
Nebraska Cowman
10-20-2004 15:48:35
you've got one of the last tractors built in 1951 if the motor has not been changed. Check the casting code to be sure; ie, trans case, top deck, etc. you should find the letter "U" or "W"
Dave_Id
10-20-2004 15:46:39
The early engine ser. numbers matched the engines, the later ones should be close enough to the tractor ser. number to use for dating the tractor. Check the casting dates to make sure they correlate to the dates on the tractor
