Rollin' it around in me head
Allan in NE
10-20-2004 17:41:24
Okay you fellers,
Tell me where I'm going wrong on this one, 'cause I haven't had a belly pump out of an H since '65 and really didn't give the silly thing much attention back then:
I remove the drive and drop the belly pump out of the tractor. I gut the pump assembly of the gears and valve assembly and just leave the body of the pump on the reservoir. Put 'er back up in there and re-attach the pipefittings, but leave the drive off.
I run a feed hose to the live pump from the former drain plug and use those three former pressure points as return ports. In effect, just making the old system a storage tank.
What say you? Crazy?
Allan
Novel Idea Guy
10-21-2004 07:37:17
 Re: Rollin' it around in me head in reply to Allan in NE, 10-20-2004 17:41:24
That's almost exactly what my Dad did to his Super M when he first got a live hydraulic pump for it 20-odd years ago...
The only problem he had was that the belly pump reservoir wasn't big enough. You had to be careful running the dump trailer up or you'd run the pump dry and shear the keyway on the drive gear. Those old tractors don't run so hot when the distributor doesn't turn...
Last winter he added a 5-gallon reservoir under the gas tank, and left the belly pump dry. It's quite a conglomeration of fittings and hoses, but it works great.
Allan in NE
10-21-2004 07:49:11
 Re: Rollin' it around in me head in reply to Novel Idea Guy, 10-21-2004 07:37:17
Do you remember what size of line he used on the feed to the pump? 3/4" or 1"?
Thanks,
Allan
Randy SE-MN.
10-21-2004 05:44:02
I "hogged out" my first belly pump on my '47 M last month when I installed the M&W live pump. It's quite a job. I drilled & tapped the proper size hole in the bottom, out the back, drilled and tapped the control rod hole, removed the guts. Really adds to capacity, and fluid stays cooler.
Allan in NE
10-20-2004 19:22:50
I gots to get this figured out as the vendor just called; all parts are located and shipping in the morning.
This is gonna be a fun project. I really like this little tractor and if I can make 'er go live, it is going to make for one sweet little outfit.
Gonna take pictures throughout the switch and might even throw up a little webpage for viewing, just for fun.
My biggest worry is the Farmhand loader. I "think" it is a closed center system, so I'll have to have at least two returns back to the tank; one for the power steering and one for the loader (if I'm thinking right).
But, with all you guy's help, we'll get er figured out. Thanks,
Allan
captaink
10-20-2004 20:50:05
 Re: Rollin' it around in me head in reply to Allan in NE, 10-20-2004 19:22:50
On my M (H would be the same) we built a tank to fit in where the belly pump was. One inch supply line to the pump, 3/4 to the valve that we mounted on the side by the belt pully. Makes a nice tidy system!
My DuAll laoder has an open center, I suspect Farmhand would be the same but not sure.
gene b
10-20-2004 19:04:07
Return in the filler neck and draw from the drain didnt even need to pull the assy as you are using the resivour that way you still had the use of the original pump and control.
DWV
10-20-2004 18:57:25
M&W made some tanks with more capacity to bolt
in place of belley one but they are scarce as hens teeth. The kits they sold to use with existing reservior recomended a 3/4 inch pipe thread hole to be drilled and taped in front lower right side of reservior for suction.Also when internals are removed they used two exspantion plugs in drive hole.If you have a 3/4
pipe tap,tap the hole were operating lever went into reservior and hook return line there.
Nebraska Cowman
10-20-2004 17:48:27
just unhook the drive, pull oil out the bottom plug and return at the filler plug. No need to remove the guts.
Allan in NE
10-20-2004 17:52:03
 Re: Rollin' it around in me head in reply to Nebraska Cowman, 10-20-2004 17:48:27
NC,
You think a guy would get enough volume through that drain plug?
Thanks,
Allan
Nebraska Cowman
10-20-2004 18:39:52
 Re: Rollin' it around in me head in reply to Allan in NE, 10-20-2004 17:52:03
i don't know. I have seen them plumbed that way and they worked.
Allan in NE
10-20-2004 17:44:39
Or,
Somebody mentioned that someone made a storage tank to replace the original?
Thanks,
Allan
Harley
10-20-2004 20:00:47
 Re: Rollin' it around in me head in reply to Allan in NE, 10-20-2004 17:44:39
Just a thought Allan, could you install a somewhat larger resevoir tank back there where your present Farmhand tank is now located, with a little fabrication of course?
Allan in NE
10-20-2004 20:25:56
 Re: Rollin' it around in me head in reply to Harley, 10-20-2004 20:00:47
Hi Allen,
My 'knee-jerk' reaction is to just take that Farmhand tank and mount it up front along the frame rail; but the more I think about it, I'd really like to keep the tractors appearance as close to stock as I can.
I just don't like the look of a cobbled tractor. But, I'll do what I gotta to get her switched. :>)
That little port block is turning out to be somewhat of a stinker. Vender just could not locate one, so he is sending a block from a 400D. He says that he held it to a 300 pump and with a little "shaving", it will fit.
Wait and see, I guess.
Allan
steveormary
10-21-2004 10:53:30
 Re: Rollin' it around in me head in reply to Allan in NE, 10-20-2004 20:25:56
Allan;
It has been a few years now but didnt the F-10,s have open center hyd.control. Dad had a live pump and a power steering unit put on his SM. Used unit and I think the pump was worn out. Seems we run a remote cyl.off that setup too. Wouldnt lift much. If I lived closer I would come up and supervise your installation.
steveormary
Allan in NE
10-21-2004 12:02:42
 Re: Rollin' it around in me head in reply to steveormary, 10-21-2004 10:53:30
Steve,
Ya better get up here; I'm runnin' 'round loose with wrenches in my hands and this just is not a good combination. :>)
I don't know about the Farmhands and whether they are "open or closed" center (mainly 'cause I don't know what I'm doin').
I studied this thing long and hard this morning. That Farmhand tank, aside from where it is mounted, it perfect for what I want to accomplish. So, this is my latest game plan:
Remove the feed line from the PTO pump and run it up front to feed the live pump.
Pressure out from the live pump to the "in" port on the proprietary valve; "exhaust port" on the proprietary valve to the Loaders 'in' port.
Loader is already dumping to the tank, so all I'll have to do is run an exhaust line from the power steering motor back to the tank.
Sound like a plan? :>)
Allan
steveormary
10-21-2004 20:24:31
 Re: Rollin' it around in me head in reply to Allan in NE, 10-21-2004 12:02:42
Allan;
Should work that way. Hope you well be alright and dont start throwin them wrenches,might hit the other half,s cat. Then you will be in trouble.
steveormary
