Super A hydraulics
Bill in VT
10-21-2004 09:27:20
Can you still get the Touch Control Hydraulics fluid on the market? or is it called something else nowadays? or is there an acceptable substitute that can be added with no problem??
Thanks
Jim Becker
10-21-2004 09:56:08
 Re: Super A hydraulics in reply to Bill in VT, 10-21-2004 09:27:20
The current replacement for Touch Control fluid is marketed by CaseIH under the name Hy-Tran. Hy-Tran itself has gone through several changes over the years (both composition and name variations) and any version will be OK in the Super A.
Other high grade brands of hydraulic fluid will work. Be sure it is labeled as compatible with Hy-Tran or all IH hydraulic systems. Most places seem to carry 2 grades of hydraulic fluid, the cheaper one usually isn't good enough and the better one usually is. If you are near a CaseIH dealer, the easiest way to make sure you have oil that meets the spec is to get the real thing.
