valve leaver clearence
Bubba
10-22-2004 00:34:41
Hay yall, what is the distance between the valve leaver and valve spring. Is this what is called the Tappet gap; if not, what is the tappet gap? I need to set my rocker arms on my M.
MagMan
10-22-2004 04:10:00
 Re: valve leaver clearence in reply to Bubba , 10-22-2004 00:34:41
Hi Bubba, If I was to make a guess I would say the lever is the part of the rocker arm that hits the top of the valve. And the valve spring is the round spring that goes over the valve on the head that returns the valve to its seated position. And the tappet gap Is the space between the valve top and the rocker arm lever when the two valves are closed. That would be when the piston is in top dead center compression stroke on that cylnder. You take a feeler gauge and put it between the valve and rocker and adjust the rocker at the push rod to the 17 thousands or what ever it is. hope this helps. JON
Allan in NE
10-22-2004 04:38:31
 Re: valve leaver clearence in reply to MagMan, 10-22-2004 04:10:00
Hi Jon,
Yep, valve lash is just like adjusting points. Get 'er around .018 to .020" and you've got 'er in the ballpark (usually). :>)
Later,
Allan
