Farmall H
A Billheimer
10-22-2004 21:29:14
does anyone know the horse power and torque for a farmall H..
A billheimer
10-24-2004 00:30:40
 Re: Farmall H in reply to A Billheimer, 10-22-2004 21:29:14
thanks
CNKS
10-23-2004 13:05:06
For the U4 power unit, same engine as H, but not run at the same governed speed, a graph in the service manual says that peak BRAKE hp (not drawbar) is about 31 at 1800 rpm, torque peaks at 110 lb ft at 1200 rpm. Governed full load speed for the H is 1650 rpm. Drawbar hp of the H is about what geneb says.
gene b
10-23-2004 03:18:53
Around 26 depending on which spec sheet you read. Torque was not rated on tractor engines.
