Slow cranking 240U
240U
10-26-2004 12:31:11
240 with NEW 6volt battery. Still cranks real slow?
What should I check ??
Randy in NE
10-26-2004 12:56:54
 Re: Slow cranking 240U in reply to 240U, 10-26-2004 12:31:11
Check/replace the battery cables. I thought that mine were ok until I took them off and saw that half of the wire strands had corroded back under the insulation. You also need a good clean connection on the starter and the frame of the tractor. As Mr. Hugh MacKay as said many times on this board, get good heavy duty cables. O or 1 gauge wires. I followed his advice and it has paid off for me.
Biged
10-26-2004 13:27:58
 Re: Slow cranking 240U in reply to Randy in NE, 10-26-2004 12:56:54
as Randy states good conn. are a must 6 volt sys. can be a pain I use 1/0 welding cable on my 53 ford (car) and it all but doubled the crank speed. No change bring the armature to a good repair house & have it tested for shorts the commutator may need to be turned & (undercut). hope this helps as I'm brand new to the wrold of tractors I've been wrenching since age 5 did my 1st motor swap on a 52 nash @ 11 for dad I'm 47
sorry for the long rep but U guys don't know me yet.
good luck Biged
