400 hyd. system
Bryce Andreasen
11-03-2004 11:39:55
I have a 1955 400 gas that i pull alot with, and do very good, even against most diesels. My hydraulic pump is lacking many hundred PSI. The main reason isn't lifting power, but for my powersteering because having over 600 lbs of weights in front isn't easy to turn. I have replaced the selector valve spring, and didn't help. I realy don't need to waste a lot of money now, but how bad and how dificlult is it to overhaul the pump? From pictures in the I&T manual, there aren't many parts. Also, to the left of the levers, i have a hole in the tin, about 3/4 of an inch, is that factory, or just a simpler way to change from singe to double acting cylenders that someone drilled?
