Low Hyd. pressure
Bryce Andreasen
11-04-2004 11:38:21
I have a '55 400 and the hyd. oil press. is several hundred psi below normal. Is it cheaper to buy a rebuilt, or how hard is it to rebuild the pump. Like all, it is infront of the distributer. From the I&T manual, there aren't many parts.
David Wence
11-04-2004 16:52:04
 Re: Low Hyd. pressure in reply to Bryce Andreasen, 11-04-2004 11:38:21
I have a similar situation only I have no pressure. I broke the tractor apart, it is a 400 to. And the hydraulic oil ran out about 2 gallons. I ran it for awhile and forgot to put the oil back in it. Just this week I put a loader on it and I can not get any pressure. I tried to prime the pump and it bubbled a lot and I could hear a sucking noise but could not get the lines to fill up with oil. Does anyone know what the problem is? The tractor has not run any hydraulics for about 10 years.
Thanks,
David
Allan in NE
11-04-2004 12:11:08
Bryce,
They cannot be rebuilt as the part that wears is the aluminum housing.
Allan
