Dual Clutch P.T.O
16535
12-29-2004 05:50:12
Hi,
Can you tell me if the: B275, 434, B250, B276, B414, have got a dual stage clutch. The type that when pressed halfway stop the wheels, and when pressed fully stop the P.T.O when engauged.
Regards.
JB2
12-29-2004 17:23:55
 Re: Dual Clutch P.T.O in reply to 16535, 12-29-2004 05:50:12
Hi, the British built B275,B276,B414,434,444 had two stage clutches, the early B250 did not.
JB2
Bob
12-29-2004 08:18:02
My "424" is set up with a dual-stage clutch, which was an option. A non-live PTO was also available. So you need to know how a specific tractor is set up. Even if it was available on that model, a certain tractor may not have it.
CNKS
12-29-2004 07:56:22
I am not sure, but I think the answer is no. I have considerable experience on a US built 444 (somewhat similar to the ones you mention), there was also a British version. I believe the drive trains were mostly the same (4-speed dual range transmission). I am so used to stomping the clutch all the way in, I am going to say no. I used the 444 mainly as a spray tractor, and I always had to coordinate and shut the sprayer valve or the pto on or off as I started or stopped. Otherwise I quickly got 100 lbs of pesticide where I only wanted one. In other words the clutch did not stop the PTO in any position, far as I'm concerned.
Matt
12-29-2004 07:00:05
This is how they established a sort of 'independent' PTO. That way, instead of in an H or M, or B, or C... You can stop the wheels without stopping your implement.
