Forget the one-wire. Get a regular Delco 10SI with three terminals. Install the alternator. Take both wires that were connected to the generator and connect them to the alternator's B terminal. Connect the alternator #2 terminal to the B terminal of the alternator or the B terminal on the starter solinoid. The purpose of this wire is to allow the alternator's internal regulator to sense voltage output of the alternator. Connecting it to the B terminal of the alternator is quick, but if you connect it to the B terminal of the starter solinoid, the alternator's regulator will get a better idea of the voltage acually getting to the batteries. Next, connect the alternator #1 terminal to somthing that gets 12 volts only when the key switch is on. On a diesel, the easiest place would be the stud on the back of the fuel level guage that has the wire from the key switch connected to it. If you were doing this on a gas tractor, you would connect to the wire from the key switch to the coil. You'll want a diode between the #1 terminal and the fuel guage, connected so power can only flow to the #1 terminal, and not back from it, because power will try to backfeed from the #1 when the engine is shut off. This is more critical on a gasser where this wire is connected to the ignition system, but it is still a good idea. There are alternator conversion harnesses alvalible made up of the plug that plugs into the 1 and 2 terminals, a diode, and the wiring for the #1 and #2 terminal connections. I think you can get them at places like TSC. Finally, take all four wires connected to your generator's regulator and connect them together and tape them up good. If you really want to get it right, late 06's came with alternators. You can buy entire new harnesses from Case-IH.
