240 Just won't run
Brian
11-25-1999 07:33:33
The other day I parked my 240, a half an hour later I got on and it just wont go. I got nothing. The starter button won't work. No compression, since I can turn it over by hand. I am just stumped by this one. If anyone has any ideas, please let me know.
I have tried to bypass the starter button, bu nothing no spark, the points won't fire. Nothing.
Thanks for any help.
Brian
Farmall Newbie
11-26-1999 15:36:23
 Re: 240 Just won't run in reply to Brian, 11-25-1999 07:33:33
I might not know much, but I had this problem with my Model M 1951....for some reason my starter hit a dead spot...and it was a simple matter of putting it into high gear and grabbing the back wheel and rocking the tractor...
Worth a try
Farmall Newbie
Paul Fox
11-25-1999 08:20:34
A bit more information would help.
I'm assuming it's electric start. If so, is the battery up? When you hit the start button, does the starter turn? If not, check the battery cables, make sure they are clean and tight. If it is, is it engaging the ring gear on the flywheel and turning the engine? If the solenoid isn't working, with starter will spin without turning the engine over. You could also have a couple of broken teeth on the ring gear and get the same results.
You say "no compression". Are you sure? You can turn most engines over by hand even at normal compression, if you turn slowly enough. Pull the spark plugs and see if it turns easier. Put your finger over a plug hole and see if you feel compression when turning it over.
I'm assuming the 240 is a late version of a C. If that assumption is correct, then the camshaft is gear driven from the crank. The only way I'm aware of to have a COMPLETE loss of compression is if the cam isn't turning, and even then, at least ONE cylinder should have both valves closed and have compression. (Of course, if the crank isn't turning, you'd get the same symptoms)
Check these things and get back to us, with more info we can come up with more things to check.
