Hydraulic problems
Bill gray
01-17-2005 11:05:59
I have been trying to find the problem with my hydraulics since I got this tractor. I have a IH 606 and it has a loader with it. But the hydraulics only work for 1 cycle. The preasure reads about 800 lbs the first time you ativate it, after that each time you do it it shows less and less preasure until it shows pretty much nothing. All other hydraulics work fine, PRW Steering, 3-pt work fine all the time. Its just the hydraulic valve at the right hand side of the op seat works good for only 1 cycle.
Anyone have any ideas?
Hermit
01-17-2005 19:04:15
 Re: Hydraulic problems in reply to Bill gray, 01-17-2005 11:05:59
Just some general ideas. Is your hydraulic reservoir vented properly? All the vent holes clear on both sides of the vent, in and out. If it's a pressurized reservoir, is the proper air pressure set?
