This is a bit of a tangent to your question but I tell everyone I hear of having a single-wire alternator setup how much happier I was when I converted my single-wire to a three-wire. If your alternator is a Delco-Remy 10SI (a good bet as they're one of the most popular anternators ever made and they're commonly used in single-wire tractor setups) it's a snap to wire up those extra terminals: Run a wire from the BAT terminal on the alternator to the #2 terminal on the alternator. Run a wire from the + side of the kill switch (same side as the wire that runs to the + side of the coil) to the #1 terminal on the alternator. To prevent a drain on the battery, wire a 1 amp, 50 volt diode (Radio Shack 1N4003 - banded end toward the alt) inline in the wire that runs to the #1 terminal on the alternator. All these new wires can be 16 or 18 gauge. You can use female spade connectors to connect the wires to the #1 and #2 terminals on the alt. If you have a 10SI alt, you can loosten the four bolts that hold it in its current 'clock' position and rotate the back half of the shell, if you need to point the wires down to avoid hitting the hood. Be careful not to pull the back half too far back as the brushes will pop out of their holders and you'll need to reinstall them. I converted from a one to three-wire setup so my alternator would start charging immediately at low RPMs. Some tasks with my tractor wouldn't require higher RPMs and the alt would never kick in. With the diode, I don't need to disconnect the battery during down-time. Hope this helps.
