generator
BrandonO
02-04-2005 18:20:12
I have a farmall C and the battery wont stay charged. How can i tell if its the generator or the voltage regulator or possibly something else?
JOSSETTE
02-10-2005 18:18:48
 Re: generator in reply to BrandonO, 02-04-2005 18:20:12
if you decide to ever change to 12 volt--i can send you a diagram.
jossejon@hickorytech.net
JOSSETTE
02-04-2005 21:29:35
the voltage reg ---regulates volts to and from the switch volt gauge and lights. the generator sends power to the battery. and then to the regulator.
put a volt meter on the battery while running it. if the volts are at 7 or 8 you have a week battery. if the volts are a steady read below 6. like a constant 4 or 3 or less the gen is shot. if the volts are up and down. 2 then 9 then 3 then 12 the reg is shot.
make sure you have a good ground cable and is secure. more problems come from that more than anything else.
gene b
02-06-2005 01:18:20
 Re: generator in reply to JOSSETTE, 02-04-2005 21:29:35
What kind of a system do you have that sends the gen output to the battery then to the reg?
JOSSETTE
02-06-2005 06:50:30
 Re: generator in reply to gene b, 02-06-2005 01:18:20
did I type that. sorry battery and regulator should be switched in the first paragragh. WOW!!
