Head Bolts
Brodie Johnson
02-15-2005 20:31:55
I was seeing if anyone knew where i could find some new or used but in good condition head bolts for an H 5 15\16 in. With the fine thread on one end and the course on the other.
champspa
02-16-2005 06:06:10
 Re: Head Bolts in reply to Brodie Johnson, 02-15-2005 20:31:55
I ordered new ones at Ih dealer about 5 bucks apiece and a few weeks to get them
El Toro
02-16-2005 04:38:27
Try your local automotive store for studs. You can find studs at a company that sells bolts, screws and studs. The local Bolt & Screw company in our area recommends you purchase a stud
that has the following designation A193-B7. It is equal to a grade 5 bolt and will withstand a temperature up to 750 degrees. If you have problem locating these studs you can call 410-687-8831. They may have them in stock. Hal
