M hydro pump pressure
Bubba
02-20-2005 09:04:23
How much pressure does the belly pump produce using 30wt. oil? Im redoing my 3pt. systen and need to replace some hose and fittings?
riverbend
02-20-2005 12:50:08
 Re: M hydro pump pressure in reply to Bubba, 02-20-2005 09:04:23
Depending on the age, it will be between 450 psi and 800 psi. You will want to make sure that your hoses and fittings are good for 2000-2500 psi. If you get a pin hole leak and get close to it, the oil will get injected under your skin. Then, if I remember right, you can get gangrene.
