hyd oil in moter oil
billy bobbb
02-20-2005 16:58:38
my hyd oil ,in my ih300, is getting into my engine and mixing with my moter oil. it then blows the extra oil out the engine overflow. any ideas what is wrong? thanks
Randy in Pa
02-21-2005 11:03:39
 Re: hyd oil in moter oil in reply to billy bobbb, 02-20-2005 16:58:38
This happened on my 230 a last fall. We put new seals in and every thing is fine now.
Randy
billy bobbb
02-21-2005 16:12:39
 Re: hyd oil in moter oil in reply to Randy in Pa, 02-21-2005 11:03:39
thanks randy, i will try new seals and see.
Redrider
02-20-2005 19:44:59
Billy, your hydraulic pump just ahead of your distributer has seals at both ends not 0-rings. Usually that seal will last as long as the pump. You can still get these seals from your Case/IH dealer. However when these pumps ware and start to go they will build internal pressure and actually push the seals out. You can try new seals and it might hold for a while. But in my case the new seal only lasted maybe an hour before pushing it out. The only real solution is a new pump.
CNKS
02-21-2005 07:28:12
 Re: hyd oil in moter oil in reply to Redrider, 02-20-2005 19:44:59
Could be that the 300 pump is different from my SH, I had it apart, and I vaguely remember o-rings. I was going to use a speedy sleeve for the groove, but for some reason it didn't fit (don't remember the details, been over a year ago). I have heard of the blowing seal thing, but the 3 pumps I have had apart were not worn, so the seal is at least worth a try, as easy as the pumps are to work on.
PAULIH300
02-20-2005 17:07:51
Engine overflow....??? Where is that?
CNKS
02-20-2005 17:39:27
 Re: hyd oil in moter oil in reply to PAULIH300, 02-20-2005 17:07:51
Probably means the draft tube, likely needs rings, also.
CNKS
02-20-2005 17:04:56
The pump shaft has an o-ring on it that is shot. Hyd oil then has a direct path to the crankcase. If the shaft is grooved, you need to have the groove filled, or use a speedy sleeve.
