504
856puller
02-22-2005 14:49:25
I have a farmall 504 wide front. I need to get the power steering valve off the shaft. i dont know if it is just siezed on or is there is a pin or something i cant see
Sloroll
02-22-2005 15:18:29
 Re: 504 in reply to 856puller, 02-22-2005 14:49:25
There is a roll pin. You will have to turn the shaft until the pin lines up with the holes on the forward end of the pump.
856puller
02-22-2005 18:06:24
 Re: 504 in reply to Sloroll, 02-22-2005 15:18:29
i couldnt see anything in that hole when i turned it but i will look again thanks
Sloroll
02-22-2005 18:14:00
 Re: 504 in reply to 856puller, 02-22-2005 18:06:24
I didn't either the first through twelfth time. Finally I drug a nail as I turned the shaft and felt it.
Sloroll
02-22-2005 18:11:12
856puller
02-22-2005 18:20:58
 Re: 504 in reply to Sloroll, 02-22-2005 18:11:12
Did you find anything bad in the valve? ours was sloppy so we changed all the crosses than it wouldnt hardly steer at all
Sloroll
02-22-2005 18:32:35
 Re: 504 in reply to 856puller, 02-22-2005 18:20:58
Mine had a broken internal pin. The dang thing kicked and bucked. You may have it aligned wrong internally. I just sold my 504 and have my parts book, maintenence IT manual and some other litterature here if you would like to borrow it. I've opened my E-mail if you would like to send me an address I'll try to get them off to you in the next couple of days. Just let me know
856puller
02-22-2005 18:39:22
 Re: 504 in reply to Sloroll, 02-22-2005 18:32:35
i have a manual but thanks. i can see thru the ports and it looks like there is some slop in something. i am going to get after it in the morning.
Sloroll
02-22-2005 18:41:54
 Re: 504 in reply to 856puller, 02-22-2005 18:39:22
Great Good luck!
