Farmall-M
Brain
12-03-1999 09:29:43
I just got a farmall and it needs alot work and parts.i don't know much on farmalls i growed up around ACs.Can someone tell me what is the can looking thing on the opecent side of the brether is it has a hole in the top of it.It looks like it has a pipe that goes on it and there is hole in the cover for the pipe what was it for.It looks like it had a bottom but has rusted out I just don't know it could be for.i was told it was a M
T-Tim
12-03-1999 16:12:21
 Re: Farmall-M in reply to Brain, 12-03-1999 09:29:43
I agree with The Red, If it looks like it would have held about a gallon of fuel, it's probally the old gas tank, which was used when starting the tractor, once running, you'd switch over to the main tank and run on a cheaper fuel. Go grab a manual at your IH dealer or telephone one, they'll mail you out and operators for $15-$20, best money spent.
The Red
12-03-1999 10:01:39
Brain it sounds like you had the duel fuel settup on that M. Must be an early one. That sounds like the auxiliary fuel tank that was used to start the M on gas, then you could switch over and run it on distillate or kerosene from your main tank.
Michael Powell
12-03-1999 19:22:09
 Re: Re: Farmall-M in reply to The Red, 12-03-1999 10:01:39
Red - you said an early model I have a 42 M and a 48 H that have the tanks , how late were the duel systems used ????
later..... .
Still available on F-450.....
12-05-1999 06:54:15
 Re: Re: Re: Farmall-M in reply to Michael Powell, 12-03-1999 19:22:09
In 1951, option cost $23.00
The Red
12-04-1999 04:52:49
Dunno Michael. Guy Fay probably has an answer for that one.
John P. Snead
09-03-2001 06:04:40
 Re: Re: Re: Re: Farmall-M in reply to The Red, 12-04-1999 04:52:49
Looking for a source of parts for my Farmall M. Please let me know if you have any informnation. Thanks,
John Snead
