Wheel Weight Part Number
Brian Schmidt
03-22-2005 20:30:22
I have a pair of wheel weights part number 370685R1. I thought they were for a Cub, but the number doesn't match what others tell me they are. Anyone know what these fit.
Thanks!!
Haas
03-23-2005 19:09:50
 Re: Wheel Weight Part Number in reply to Brian Schmidt, 03-22-2005 20:30:22
For one, they are front wheel weights for a 140 with disk front wheels. Should have 4 bolt holes. Approximate weight 50 lbs.
Brian Schmidt
03-23-2005 19:33:25
 Re: Wheel Weight Part Number in reply to Haas, 03-23-2005 19:09:50
Thanks Haas. Yes they have 4 bolt holes. Must be for the 140. Do you know if they will fit the Cub?
haas
03-23-2005 19:51:20
 Re: Wheel Weight Part Number in reply to Brian Schmidt, 03-23-2005 19:33:25
Won't fit the Cub according to my parts CD, that part number is not shown for the cub. If the bolt holes would fit, you could use them I suppose. They will also fit 200, 230, 240, and propably other tractors that have the pressed steel disk type front wheels with 4 bolt holes for wheel weights.
Jim Becker
03-23-2005 20:33:10
 Re: Wheel Weight Part Number in reply to haas, 03-23-2005 19:51:20
The 200 and 230 normally have 3 spoke wheels and take 3 hole weights. This weight is correct for a 240.
