Water Temp Sending Unit For My 49 C
bamalarry59
04-06-2005 15:55:52
My 49 C has a water pump on it, but the sending unit looks like it has never been screwed in. Still has the paint on the threads. Dash has the temp gauge and wire lead. There is a plug in the water pump that I have removed. Only problem is when you screw in the sending unit it doesnt bottom out. Anyone know what I need to do to solve this problem? Thanks, Larry
bamalarry59
04-08-2005 17:10:29
 Re: Water Temp Sending Unit For My 49 C in reply to bamalarry59, 04-06-2005 15:55:52
I thought the hydrolic gauge was for the super c"s and was mounted at the touch control unit. My temp gauge is mounted in the dash..... .
Problem is with the fitting and the tap in the water pump. I would just like to be able to monitor water temps.....
haas
04-07-2005 18:38:38
Are you sure the temp gage is not the one for the hydraulic unit. Most Cs did not have a water temp gage unless they were distillate or kerosine tractors. However, many did have a temp gage on the hydraulic unit.
gene b
04-06-2005 19:10:26
That is where it goes.
