Super M broken bolts in break housing
Brian Setlak
04-08-2005 09:52:52
On my 52 SM, a few of the bolts that hold the outer break housing on the rear end housing have broke. I've got the part that holds the disc's off. The next part with the broken bolt's in look's to be a bearing carrier? Question is how do I get that peice out so I can drill and tap the bold holes. Does the bearing and the shaft come out with that housing? Thanks
r4etired
04-08-2005 18:01:08
 Re: Super M broken bolts in break housing in reply to Brian Setlak, 04-08-2005 09:52:52
Brian, I bought a 350 utiliy cheap, the guy thought the rear endwas bad, One the 350 when these bolts break it lets the pinion come out a little on the ring gear. sounds real bad then. My bolts came out pretty easy using a small chisel,I think the bolts work a liitle loose,then when the brake are applied hard it shears them off eventually, There are shims behind the bearing cage that you move from side to side or remove to adjust the ring gear pinion clearance.
Haas
04-08-2005 14:03:42
Don't try to pry out the bearing carrier. It can't be removed unless you open the transmission and take the bull gear off the axle. The Bull gear runs in a slot in the bearing carrier.
El Toro
04-08-2005 12:24:33
Can you heat those broken bolts with a torch without damaging the bearing carrier? Hal
Nebraska Cowman
04-08-2005 10:15:53
The carrier won't come out without removing the bull gear.
