Order Farmall Cub Parts Online
Farmall Cub
billde
04-14-2005 16:04:48
Just brought home a 1959 cub. Where do I check the hyd fluid level, and where is the fill hole? Thanks!
RAW in IA
04-14-2005 17:14:08
 Re: Farmall Cub in reply to billde, 04-14-2005 16:04:48
On the left side of the hydraulic unit is a hex plug, about 15/16" or so. I believe the hydraulic lift arms are supposed to be in the rear position and the oil should be up to the bottom of this hole, which is also the fill hole. Be sure to wipe the dirt away good before taking the plug out. It should have a copper gasket on it also.
