Super M
Andre'
04-19-2005 13:04:18
Are there any differences in the 4 inch bore and the 4 1/4 inch bore when I am replacing the piston and sleves. Flat pistons came out of it but because of the altitude I am at, I want and it calls for the step Pistons. Is it alright to put the step ones in and the 4 1/4 inch bore pistons and sleves.
supermpuller
04-19-2005 14:08:51
 Re: Super M in reply to Andre', 04-19-2005 13:04:18
On a SM you can go from 4 in. to 4.125 with thin sleeves, if you want to go to 4.25 pistons you have to bore block, firecraters or stepped pistons will work , shave a little off head will help compression too.
