Farmall-IH I460 Diesel
Andy Harris
12-09-1999 13:38:13
I just bought a Farmall McCormick IH I460 Diesel Tractor. It has the HydraTouch hydraulic system and also appears to have the auto-leveling device that came on the Utility tractors. It is also a high clearance vehicle.
I am having trouble finding any good tech books on how to repair the leaks in the hydraulic valves below the steering column that comprise the Hydratouch system.
The tractor has had an IH front loader system added on to it, and the loader spool valves were added external to the Hydratouch system, making the result even more confusing.
Does anyone have a great source of hydraulics information for this beast??
Harold H
12-10-1999 04:45:49
 Re: Farmall-IH I460 Diesel in reply to Andy Harris, 12-09-1999 13:38:13
You have an overlap of names so we are not sure what tractor you have. Do you have a Farmall 460, or a International 460, or a Farmall 460 Hi Clear, or a International 460 Hi Clear? They are different. Manuals are available from a number of the on line advertisers on Yeaterday's Tractors.
Harold H
wayne
12-10-1999 03:51:26
Get an IT shop manual. Is this a high utility tractor?
Andy Harris
12-11-1999 10:32:31
 Re: Re: Farmall-IH I460 Diesel in reply to wayne, 12-10-1999 03:51:26
I think this is a "high utility tractor" because it has 38.5 inch rear tires and is way up in the air compared to either the 450 or 460 pictures in the tractor history books.
I am having trouble identifying the precise year this tractor was made because of the confusing markings. It has a large "Farmall on the chrome side strip, with the word "McCormick" in smaller letters on the chrome above it. ON the front grill the IH logo is placed in the upper section. Many of the stamped numbers on the castings have IH designators.
The Hydratouch valves located directly under the steering column are leaking badly. If I can get seals for these valves, I can use the tractor almost immediately. The engine, gear, etc. seem to be in pretty good shape.
I don't know the "IT manual" shop manual that Wayne is referring to. This isn't IH is it? I have the IH shop manuals that the Case Dealership currently stocks for this tractor. These manuals neglect the hydraulic system entirely.
I would appreciate any information that anyone has on how this hydraulic system operates, or particularly any manuals, shop specs; or other tech info on how to rebuild this system.
Andy Harris
