Worksaver 3pt
Bill in VT
04-25-2005 04:43:53
Does the "Worksaver 3pt hitch" adapter work with a Super A? If so, is the purpose of the worksaver to eliminate the offset to the PTO? or does it just allow implements to be lifted up and down??
I want to use a brushog this summer, but I keep getting mixed opinions on if it works or not, and then how to hook it up. Some say the offset is not a problem, others say it is?
Any help out there?
Greg Slocum
04-25-2005 05:16:58
 Re: Worksaver 3pt in reply to Bill in VT, 04-25-2005 04:43:53
The worksaver will not change the offset of the PTO on the SA. Basically, you end up with limited up and down movement because the PTO shaft u-joints will tend to bind sooner due to already turning the offset corner. While effectiveness is limited as compared to a center PTO unit, once you understand the inherent limitations of the ofset, you can use it without issue. Hope this helps.
greg
