SA won't start after running it out of gas
Bill57
04-25-2005 17:55:42
The SA was running well, and we had almost finished with the 2 disc breaking plow, just beating the rain (again.) Love that plow. But then we ran it out of gas. I filled it up, hit the starter, it would cough a bit and then die. (Usually it started right up.) Then, after a few near misses at starting, there was no cough at all, not even a little one. Then the starter began grinding (12 volt) - wouldn't catch at all even by pushing the switch instead of pulling the handle. Cranking also got no response. I think the carb's in decent shape, the gas line is running when I take it off the carb to look, the gas is open to the tank and running well, the sediment bowl is clean. Anybody have an idea what's going on? Is there something that typically happens when an SA is run dry?
Thanks very much for your consideration,
Bill in west-central Alabama
Try Filling It Up First
04-26-2005 21:00:08
 Re: SA won't start after running it out of gas in reply to Bill57, 04-25-2005 17:55:42
Bill57
04-27-2005 07:29:11
 Re: SA won't start after running it out of gas in reply to Try Filling It Up First, 04-26-2005 21:00:08
It's a wonder anyone replied at all with that subject. You get engrossed in the process and forget about minor flaws in writing about it. A "can't see the forest for the trees" thing. Leave yourself wide open. Funny stuff.
El Toro
04-26-2005 04:17:29
I would pull a sparkplug to see if they're wet or
dry. It will probably start this morning after sitting all night. If it doesn't try holding
your hand over the throat of the carburetor to see if it will start. How's the pecan crop going to be this year? Hal
Be careful doing this and make sure brakes are locked and out of gear.
n9lhm
04-26-2005 07:34:29
 Re: SA won't start after running it out of gas in reply to El Toro, 04-26-2005 04:17:29
I used to do the hand over the carburetor trick until one day one backfired and burned the skin off my palm. :( Now if the choke won"t close fully I fix it first instead of using my hand.
El Toro
04-26-2005 08:17:01
 Re: SA won't start after running it out of gas in reply to n9lhm, 04-26-2005 07:34:29
I bet that would hurt, we used that on cars that we thought had bad fuel pumps. Hal
Don L C
04-25-2005 19:49:09
Sounds like it has sucked a small piece of dirt into a needle jet...remove the high and low speed jets and carefully blow through the needle and seat with compresed air....carefully screw the needles back in all the way, CAUTION do not run them in tight.....back the low speed screwout 3/4 turn --- the high speed out 1 1/2 turns, it should start....adjust low speed ssrew in/outuntil it runs the smoothest..... .at full throttle adjust until it runs the smothest and the fastest..... .
Hermit
04-25-2005 19:42:37
If you filled the gas tank and tried to restart shortly after it ran out of gas, the engine might have vapor locked. If you were plowing, the engine was probably running on the warm side and might have heat-sinked the carb. I'd just try to normally start the tractor and troubleshoot any problems from that point.
gene b
04-25-2005 18:08:04
sounds like the float was stuck and it got flooded. Open throttle full to start. Mite have to tap the carb to unstick the float.
Bill57
04-25-2005 18:31:32
 Re: SA won't start after running it out of gas in reply to gene b, 04-25-2005 18:08:04
Sorry, I should have mentioned that I took the carb off,opened it up, and checked it out as best as I know how. Do you think I should start to hand crank it with full choke tomorrow?
Farmer Bob
04-25-2005 19:43:42
 Re: SA won't start after running it out of gas in reply to Bill57, 04-25-2005 18:31:32
You could have sucked a piece of sediment into a passage in the carb when she ran out of gas. At least you can eliminate that by checking it out.
Bill57
04-25-2005 20:33:54
 Re: SA won't start after running it out of gas in reply to Farmer Bob, 04-25-2005 19:43:42
Thanks much for all the replies. I'll check 'em out tomorrow first thing. I can't say enough about all the help this site provides me; for a newcomer to farming - and tractors - y'all can't be beat. Looking forward to the day when I'll have something to add.
