Hydraulic cylinders
300Randy
04-28-2005 09:18:51
Do the hydr cylinders have a stop inside or will the shaft come poping right out if its not hooked to something? The reason I'm asking is that I want to take the bucket off of my front end loader and when I do the cylinder won't be attached. I was wondering if I accidently hit the controls then would it pop the shaft out and I'd lose all the fluid. Can this happen or do most cylinders have an internal stop?
old
04-28-2005 09:39:18
 Re: Hydraulic cylinders in reply to 300Randy, 04-28-2005 09:18:51
No worrys about that the shaft of the cylinder is smaller then the piston so it can't pop out on you unless the shaft has a problem but you would already know that because the cylinder wouldn't be working right
big fred
04-28-2005 09:46:31
 Re: Hydraulic cylinders in reply to old, 04-28-2005 09:39:18
If it's the loader cylinders on the (U34?) loader on the 300U, those don't have a piston. It's a one-way ram, and the shaft is the piston. There is a steel retainer ring on the bottom end of that shaft that will keep the shaft from coming out.
