MW throttle
AJB
05-19-2005 04:20:52
Cleaning up and installing M&W friction type throttle on my H. What is the material used in between lever and base plate. I got the throttle off a tractor that set out for years. The gasket like material is falling apart and turned green. Not sure what to replace it with. Thanks Andy
Randy SE-MN
05-19-2005 05:05:42
 Re: MW throttle in reply to AJB, 05-19-2005 04:20:52
Friction kits are available on Ebay, and also OEM tractor parts catalog
Bob M
05-19-2005 04:49:14
Suspect the original friction disk was some sort of semiflexible asbestos or composition material.
I had the same problem (disks worn thru or missing) with a couple of M&W throttles on my tractors. I purchased a sheet of 1/8" thick asbestos(?) impregnated, high temperature gasket material at a steam show and cut my own friction disks out of it. The disks are still working great after 5+ years of service.
Tip: If the mating iron surfaces on the underside of the lever handle and the mounting base are rusty/rough, sand 'em smooth before installing the new friction disk.
