just to be sure.... is this correct ?
arod
05-20-2005 12:05:41
ok... Hmmm. So should a fella NOT wire up to the junction block where the ignition comes together behind the switched side of the ign switch.
Three wires exist on that junction to be exact:
1) wire from the alternator that reads "TO BAT"
2) wire supplying current to the ign switch
3) wire to the positive battery cable for charging
This is NOT the place to grab a 'hot' for accesories then?
captaink
05-20-2005 12:10:17
 Re: just to be sure.... is this correct ? in reply to arod, 05-20-2005 12:05:41
I don't see a problem with it as long as the wire supplying the junction block from the battery is heavy enough to carry the current.
arod
05-20-2005 12:15:06
 Re: just to be sure.... is this correct ? in reply to captaink, 05-20-2005 12:10:17
well alright! thanks for the review of how I wired the junction. I have a 10 guage wire from the positive battery cable to the junction block. So, cool. That seems to be correct. And you concur that a little oil will smoke like the dickens.
Thanks for your review and comments, helps tremedously to have other peoples wisdom when tackling problems. Thanks captaink
