Six or 12 Volt Battery?
billcrews
07-03-2005 06:02:55
I bought a McCormick Deering W-4 standard gas tractor and it did not have a battery with it.
What are some of the clues to tell whether it will require a 6 volt battery or 12 volt battery?
I think the tractors were originally designed for a 6 volt battery with positive ground. The tractor now has an alternator coming off the side of the engine; is that a clue that it is a 12 volt system? Also, if it turns out that it is a 12 volt system, should the ground be negative? Lastly, what will happen if you hook up a six volt battery and the system is designed for 12 volts?
Thanks
Don L C
07-03-2005 18:35:36
 Re: Six or 12 Volt Battery? in reply to billcrews, 07-03-2005 06:02:55
My guess is its 12v.....check the light bulbs..Generally the alt.is used on 12v...
P Backus
07-03-2005 10:59:53
My personal bent would be to put it back like original. That way there is no guessing. 6V is all a W4 needs. I changed my SW6TA back to 6V when I bought it. Of course, it's up to you.
Paul
RAW in IA
07-03-2005 06:17:42
With an alternator it is almost certainly 12 volt and negative ground,. I have never seena 6 volt or pos. ground alternator.
RustyFarmall
07-03-2005 06:20:20
 Re: Six or 12 Volt Battery? in reply to RAW in IA, 07-03-2005 06:17:42
There is such a thing as a 6 volt alternator but it is highly unlikely that the tractor has one.
CNKS
07-03-2005 10:54:54
 Re: Six or 12 Volt Battery? in reply to RustyFarmall, 07-03-2005 06:20:20
1st I ever heard of 6 volt alternators was from Hugh McKay. Just did a Google search and the link was nearly the first thing to show. I have never seen one.
