Super A decals
Bob
12-16-1999 14:50:26
where do the O D B & L H D B decals go?
If your switch has.......
12-16-1999 16:54:44
 Re: super A decals in reply to Bob, 12-16-1999 14:50:26
3 positions use the O D B. If it has 4 positions use the L H D B [low charge, high charge, dim, bright.] Usually the 4 position is found on early Farmalls. As far as I know, they were used on USA tractors.
Daniel
12-16-1999 15:43:37
third party image
A picture is worth a thousand words. I believe the other decal L H D B was not used on the U.S.A. tractors?? O D B = Off Dim Bright. Hope this helps.
Farmer Bob
12-16-1999 18:57:11
 Re: Re: super A decals in reply to Daniel, 12-16-1999 15:43:37
Daniel, That's a sharp looking SA. Wish mine was a super for the hydraulics. But.... Nice job on the alternator mounting also. Looks neat. FB
Kevin
12-16-1999 16:22:07
Daniel, Is that your Super A that you just restored? Let's see some more pictures!
Daniel
12-16-1999 16:53:23
 Re: Re: Re: super A decals in reply to Kevin, 12-16-1999 16:22:07
third party image
Finally, here's a before picture. I wish now I had one before we took off the sheet metal. Would you believe a broken generator belt started all this? It just kept on with "We might as well... while were this far"!
big fred
12-16-1999 17:08:34
 Re: Re: Re: Re: super A decals in reply to Daniel, 12-16-1999 16:53:23
Bet that was a bear to move into the shop from there. I moved my B in and out of the shop several times with the steering unhooked, was a pain each and every time. ;o)
Daniel -All three posts are different pictures
12-16-1999 17:25:50
 Re: Re: Re: Re: Re: super A decals in reply to big fred, 12-16-1999 17:08:34
I would never want to do it by myself!
Daniel
12-16-1999 16:49:19
third party image
Here's the other side. Pretty much like it was in '51 except for the alternator conversion. How do you like the mount? I wanted it tucked up close but I almost got it in the way of the front hood latch!
Jamie Fay
12-18-1999 17:00:15
 Re: Re: Re: Re: super A decals in reply to Daniel, 12-16-1999 16:49:19
Boy, that's a beauty of a tractor. I have a 140 which I am going to convert to 12V alternator. Can you tell me what you had to do for a mounting bracket? It looks like you added something substantial.
thanks
Daniel
12-18-1999 19:33:43
 Re: Re: Re: Re: Re: super A decals in reply to Jamie Fay, 12-18-1999 17:00:15
The bracket is made from the orignal generator bracket(it had be welded before so I didn't mind sacrificing it)with a piece of angle iron turned over it and welded to crate a flat top surface. The bracket is a off-the-shelf GM dress up bracket from Mr. Gasket bolted to the angle iron in sloted holes so the pulleys can be lined up. The top adjusting bracket is from a 50's small block chevy cut to length and mounted to a bolt in the top water neck. The pulley is from a 70's GM, it's narrower than the later v-belt pullys and works better with the tractor pulley. Good luck.
jakee
12-16-1999 17:21:39
class A
Daniel
12-16-1999 16:44:35
third party image
Sure is. Here is a picture with my dad on it, he bought the tractor in the 50's we just restored it.
Marvin
12-16-1999 18:00:22
 Re: Re: Re: Re: super A decals in reply to Daniel, 12-16-1999 16:44:35
Daniel;
What all did you do to the Super A in the restoration? Was it pretty much clean, sandblast and paint or did you do some repair also? I have aSuper A that I want to restore to good working condition. I have to wait until my son gets his H out of the shop.
