HELP NEEDED! Brake bearing seal on Farmall 350
Andy in MN
07-08-2005 05:22:44
My brakes have never properly worked on my Farmall 350, but since I live on flat land it has never really bothered me. Last night I decided to start digging into the problem. Any who, I noticed that the right brake was fully coated with tranny fluid when I took it apart.
My question is: How difficult is it to replace this seal? I can't seem to figure out how to get the bearing housing off the side of the tractor.
As always, thanks in advance.
Andy
DWV
07-08-2005 13:43:50
 Re: HELP NEEDED! Brake bearing seal on Farmall 350 in reply to Andy in MN, 07-08-2005 05:22:44
Bearing retainer and brake plate with bull gear pinion seal is a slip fit after outside brake housing is removed.It has an o ring to seal it in the bull pinion bearing housing.If you look around the outside of retainer you will find some slots to pry out with.Use 2 pry bars to keep straight.Or the way I do most of time is screw slide hammer in threaded hole in end of bull pinion gear shaft and slide shaft,bearing and plate out in one whack.
