Order Farmall Cub Parts Online
Farmall Cub rear wheel weights
Brent in IA
07-13-2005 08:48:42
I just bought a 1951 Farmall Cub for my brother, it is being delivered later this week. It appears from the picture I saw (haven"t seen it in person)that the right-rear wheel counterweight is not there. Is this a special size/bolt pattern just for the Cub, or will weights for an H or another Farmall fit on it?
The Cub is coming from Michigan, will spend a month in Iowa to get put into shape, then move to Montana in August to my brother"s place. Will I need to do any high-altitude adjustments to the carb since the air is thinner out/up there?
Bigdog
07-13-2005 11:03:17
 Re: Farmall Cub rear wheel weights in reply to Brent in IA, 07-13-2005 08:48:42
Weights from an A / Super A will bolt on. But check the inside of the wheel center. I have one cub with the rears dished out and the weights are on the inside and at first glance, it appears that there are no weights on the tractor.
