oil leak
51H
07-16-2005 03:18:27
I rebuilt my sons 51H and it started leaking oil,So we split the tractor again to replace the rear seal,Got it all back together and drove it down the road,When he got back he parked it on slap in front of the shop and it was leaking oil agian..... .What am I overlooking? My son is 12 ye ars old and hes talking about FIRING me Thanks for your help. Doug
Pappy
07-20-2005 17:13:19
 Re: oil leak in reply to 51H, 07-16-2005 03:18:27
Doug--couldn"t get E-Mail to work. Anyway, the holes were just above the rear main bearing about two inches and spread out about 3 inches. They were clean holes that opened into the crankcase just below the cylinder, allowing oil to splash out through them. Never did find out what they were for. since they are in front of the flywheel, couldn"t be locator dowel holes, unless the engine was originally intended for industrial or pump use and had different attachments. This is pure speculation on my part. Hope you git "r done.
Pappy
07-16-2005 20:46:00
My son had the same problem. Leaked big time. Changed the seal--still leaked bad. Second tear-down he discovered two holes in the back of the block which should have some sort of pin or plugs in them, but did not. Two open holes. He threaded the holes and put plugs in them. No more leaks.
51H
07-18-2005 02:49:48
 Re: oil leak in reply to Pappy, 07-16-2005 20:46:00
Pappy.... How big where the holes? And where were they at?
51h
07-17-2005 02:43:18
Thankyou,I do belive thats what I forgot...Doug
51h
07-16-2005 11:27:02
The oil seal is just a simple felt seal, The crank was turn .10 under when we overhauled it. Someone told me to goop the seal up with silicone or to even boil the felt first.
GeorgeH
07-16-2005 09:50:14
Groove in crank ? Rear main bearing ? Don't know what seal looks like but is it facing right direction? Just guesses..... .....semi educated.
