Jumping out of gear?
53DC
07-27-2005 09:39:36
My B runs fine in every gear except when under heavy load in 1st gear. It has jumped out of gear several times recently when pulling it hard. Any suggestions on what is causing this?
Hugh MacKay
07-27-2005 16:04:53
 Re: Jumping out of gear? in reply to 53DC, 07-27-2005 09:39:36
Your transmission gears may be just fine if it hasn't been doing this very long or often. My Farmall 130 did this once. Next rainy day I removed transmission cover, gears looked fine. What I discovered though was detent ball and spring which holds shift rail in 1 st gear were all rusted and seized. I got new parts from CaseIH cleaned it up and it's worked fine ever since.
Don't allow this to continue or it will wear the gears. Now as others said you may well have gear wear already, and if so new ball and spring will not likely cure it. I was lucky as I knew the history of my tractor, thus caught it in time.
scotty
07-27-2005 11:03:19
As Andy says, worn gears. My A does this up steep incline with a load. Try second gear and throttle back a little for the same speed, it works for me!
scotty
Andy Martin
07-27-2005 10:25:28
Worn transmission gears, and maybe worn shifter.
