Farmall C
billde
08-05-2005 05:17:18
just bought a Farmall C what oil should I use in the hydraulic system? Thanks
1031D
08-06-2005 00:19:38
 Re: Farmall C in reply to billde, 08-05-2005 05:17:18
I use Hy-Tran from CIH in everything, doesn't foam.
achodges1
08-05-2005 21:58:47
I saw a service manual that recommended 10W motor oil. I use mobil 424 hydraulic oil and it works just fine. Any hydrolic oil will be fine.
chamspa
08-05-2005 16:42:39
use a 15 or 20 non-detergent
Nat
08-05-2005 06:04:38
Short answer: Hydraulic oil.
Long answer: The manual will recommend "Touch Control Fluid" which is no longer available. Besides, it's nothing special. Most oils aren't anything special. The major difference between oils of different type is the viscosity, how thick the oil is. Gear oil is really thick. Hydraulic oil is thin. Motor oil is somewhere in between.
Get yourself a jug of good quality hydraulic oil and don't lose any sleep over it. If you have a CaseIH dealer near you, their brand is HyTran.
