Farmall A
blocks
08-23-2005 17:39:11
On the steering coulm wher the mag kill switch is bracket that holds the switch there is a thing that looks like a vacume deiafram with a linkage that does,nt go anywhere the tractor is gas only . it is a 1940 has never ben panted thanks sorry about my spelling
will sick
08-23-2005 19:51:14
 Re: Farmall A in reply to blocks, 08-23-2005 17:39:11
That was part of the pneumatic lift control that these tractors had. You could pull the lever and when the implement was as far up as it should go this diaphram kicked the lever back to the neutral position.
Jim Becker
08-23-2005 19:31:58
Is there supposed to be a question somewhere in there?
Billde
08-23-2005 20:21:35
 Re: Farmall A in reply to Jim Becker, 08-23-2005 19:31:58
Yes, there is a question there. What is the vacuum diaphram and linkage for? Will and I got it, didn't you?
Jim Becker
08-24-2005 20:09:57
 Re: Farmall A in reply to Billde, 08-23-2005 20:21:35
If that was the question, Will got both the question and the answer right.
