IH240
BobG
09-19-2005 09:23:37
I just bought a 240 thats in wonderful shape. Its my first tractor. It ran wonderfully for a short time and then would cut off. I took off the gas tank and cleaned it. There was a lot of sediment. I cleaned the sediment bowl. But after starting it back up I had the same problem. It would run fine for a few minutes then almost stall then run fine for a few seconds etc... then stall. Could there be a similair problem in the carb. Is there any type of inline filter on this model? Thanks.
El Toro
09-19-2005 09:46:44
 Re: IH240 in reply to BobG, 09-19-2005 09:23:37
You probably have some of that dirt in your carburetor. The main jet may be clogged too.
Pull the fuel line off at the carburetor and see if there's good fuel flow. Trace the fuel line from the tank to the carburetor look for an in line filter. I doubt if it has one. Clean that carburetor and see if it runs ok. If the 240 has a main jet adjusting screw like the H and M
at the bottom of the carburetor open this some by
turning it CCW. Hal
Nat
09-19-2005 12:31:08
 Re: IH240 in reply to El Toro, 09-19-2005 09:46:44
Best to take the carb off and clean it out, too.
El Toro
09-19-2005 18:22:35
 Re: IH240 in reply to Nat, 09-19-2005 12:31:08
I would hope he would remove the carb and clean it. Hal
