Order Farmall Cub Parts Online
Cub 12 volt Starter
Bob G.
12-27-1999 10:07:12
I want to convert my Cub to 12 Volts and the starter needs replacing anyhow. I think the later Cubs were 12 volts, or at least there is a wireing diagram in my reproduced shop manual that shows a 12 volt system. Will the later Cub Starters work on my 1952 Cub? Thanks in Avance Bob
Jim Becker
12-27-1999 19:38:32
 Re: Cub 12 volt Starter in reply to Bob G. , 12-27-1999 10:07:12
The 12 volt starters probably have lugs for an external solenoid rather than the set-up for a switch screwed directly to the starter.
I wouldn't change it anyway. If it doesn't start OK on 6 volts, something else needs to be fixed. Mag equipped Cubs seem to actually start better on 6 volts.
Jeff
12-27-1999 13:18:50
I,don't know about the 12 volt starter, but I changed a 48 Cub over in 92 for my neighbor. I used the original 6 volt it still works great. An mechanic told me that 12 volts were easier on these old 6 volt starters. I don't know how much help that is but it's what I know about it.
Burrhead
12-27-1999 16:34:24
 Re: Re: Cub 12 volt Starter in reply to Jeff , 12-27-1999 13:18:50
I think you're right Jeff. I would rebuild the 6 volt starter and use it.
I don't ever remember seeing a 12 volt cub that came originally as 12 volts..
Jeff
12-27-1999 13:17:57
