C Hydraulic Parts
Brian Schmidt
12-27-1999 20:24:35
I have had no luck finding an auxiliary control valve, handle, or tubes for an International C. What’s up with that? Are these that rare? IH no longer has the valve either. I am buying a 3 point conversion this week from Saginaw Tractor and need to find one soon. Please help, anyone…….
John McDevitt
12-28-1999 05:10:11
 Re: C Hydraulic Parts in reply to Brian Schmidt, 12-27-1999 20:24:35
For what it's worth, any Super C with a fast hitch uses the same valve, manifold, linkage and lever. I found one a couple years ago for a Super A which is almost the same setup.
Good luck.
John McDevitt
Rob R
12-28-1999 17:57:26
 Re: Re: C Hydraulic Parts in reply to John McDevitt, 12-28-1999 05:10:11
I found a bussiness for parts for my C and Super C. If you're interested give Wengers a call
1-800-451-5240. Good luck,hope this will helps.
Les s Repair
12-30-1999 19:29:23
 Re: Re: Re: C Hydraulic Parts in reply to Rob R, 12-28-1999 17:57:26
I have an adapterthat goes between the manifold from the hydraulic pump and the resavore. Give me A call 515 847 2731.
