U4 power unit with mech. fuel pump
AC
10-20-2005 16:43:10
Picked up a U4 power unit motor last week because I need a block for my pulling engine. I noticed it has a fuel pump that runs off the cam, and quite a bit more areas to tap into the oiling system. Are these any better engines than regular H motors?..THANKS, AC
chadd
10-21-2005 09:11:32
 Re: U4 power unit with mech. fuel pump in reply to AC, 10-20-2005 16:43:10
It seems that most of the power units had more power than their respective wheel tractor counterparts. It was probably set to run at a higher full load rpm as well. The fuel pump isn't really necessary for a tractor, because the fuel tank is above the engine, and gravity flow does the job. Maybe someone more familiar with IH power untis can give you a hand.
