Farmall c
Ben Rauls
10-23-2005 17:10:31
I just bought a C and was wondering if there are any problem areas, with them. I have an M, but dont know how similar they are or what? I bought it just for snow, it has a straight blade on the front, and mabey cutting wood. Just want to know what you think of them.
Bill Geer
10-23-2005 18:11:09
 Re: Farmall c in reply to Ben Rauls, 10-23-2005 17:10:31
Try to hook it up so you push off the rear axle.
Ben Rauls
10-23-2005 19:15:29
 Re: Farmall c in reply to Bill Geer, 10-23-2005 18:11:09
it already has the plow and frame, it looks like its supported pretty good off the rear end.
Nat
10-23-2005 17:44:00
Like all of the old Farmalls, they're rock-solid. The only weak point as I see it is the frameless design. Using it to push snow will put lots of stress on the engine, and you could break it in half quite easily, or at least crack the block if you hit something hard with any momentum.
Remember that this isn't a bulldozer or a battering ram, and you should be okay.
