seat shock bolt 49 M
Bob Underwood
10-25-2005 03:38:03
I am trying to put the seat back to original the shock was missing. Would someone explain what it looks like. I have tried to buy one no luck. Thanks Bob
Randy in NE
10-25-2005 04:06:39
 Re: seat shock bolt 49 M in reply to Bob Underwood, 10-25-2005 03:38:03
For tractors F-501 to F-28174 and L-500001 to L-504801 there is not a shock absorber. Different design. For F-28175 Up and L-504802 to L-512541 it is part number 351750R93. You will need four of the rubber grommets. For the "Hydraulics Seat (Special)" it is 353204R93 and you will need two rubber grommets. 351750R93 has a loop on each end of the shock absorber and has a rod with two of the rubber grommets on each end. 353204R93 the shock absorber has a loop on one end with the rod and rubber grommets. On the other end it has a threaded shaft sticking straight out the end with two different shaped rubber grommets, more like the shocks on the front of a car.
Bob Underwood
10-25-2005 09:10:03
 Re: seat shock bolt 49 M in reply to Randy in NE, 10-25-2005 04:06:39
Thanks Randy ; This is the shock with a loop on one end and a stem on the othe. What I need is the bolt that goes through the bushings on the loop end. Thanks Bob
Randy in NE
10-25-2005 10:54:06
 Re: seat shock bolt 49 M in reply to Bob Underwood, 10-25-2005 09:10:03
If you would like I can e-mail you a page out of the parts manual that has the exploded view and the parts list. My e-mail is uncovered.
