M push pull ignition switch
Bob Underwood
11-01-2005 02:49:19
Ignition switch has been removed from my 49M, I would like to know if there is a difference between switch for mag and distributor
Thanks Bob
Haas
11-01-2005 06:24:21
 Re: M push pull ignition switch in reply to Bob Underwood, 11-01-2005 02:49:19
The one for the magneto just grounds the magneto when you push it in so it only has one connection. When pulled out the switch is open so no current flows. The one for the battery ignition is a standard single pole switch with one contact and two connections. Switch contacts are open when pushed in, closed (ignition on) when pulled out.
C Davis
11-01-2005 03:31:07
Yes the mag has one post and dist has two
Bob Underwood
11-01-2005 04:36:53
 Re: M push pull ignition switch in reply to C Davis, 11-01-2005 03:31:07
Thanks. E-Bay has one of the mag type thought I should chec. The tractor I have has a distributor. Thanks
Bob
Peabody
11-01-2005 05:22:25
 Re: M push pull ignition switch in reply to Bob Underwood, 11-01-2005 04:36:53
You can get a new one from OEM Tractor Parts for $51.00 (!?!?!?!?!).
TKN
11-01-2005 09:22:27
 Re: M push pull ignition switch in reply to Peabody, 11-01-2005 05:22:25
Can you use a two post type on a Mag system?
Sorta
11-01-2005 09:33:05
 Re: M push pull ignition switch in reply to TKN, 11-01-2005 09:22:27
Yes by running wire from 1 post to ground but then it will be out to stop and in to run.
