rear axle to rear axle width, farmall H
arod
11-02-2005 11:53:17
I have an opportunity to rent a 24X24 garage, and was curious the outside axle width of farmall H's, as I want to know if three will fit side by side in there.
williamf
11-02-2005 12:47:50
 Re: rear axle to rear axle width, farmall H in reply to arod, 11-02-2005 11:53:17
I just measured Mr. Haney. He's got standard axles and the tires are set with the rubber sticking out about two inches past the end of the axles. Just under seven feet wide.
And if at least one is narrow front and you put it in the middle, backed in; plenny room.
Wm
